IS200 Battery Dead! Help! ASAP Please
SexyLexi
Help Needed!
Put a Sony stereo into my IS200, but it is causing flat batteries!
The clock and cig lighter is always on 12v even if keys are out
Any way to fix this preferably without buying a different lead?
Post some pics of how you've wired it in please... Sounds like you've wired the stereo into the permanent live (yellow) rather than the switched live (red) I thinkkkkkkkkkk
Pics say a million words... (I saw that written once before)
Sent from my CLT-L09 using Tapatalk
its powered by a piggyback fuse connector into the fusebox on the passenget footwell
thr Battery is dying aftet sitting for one day, alternator and Battery have been replaced
the amp has been removed also, is this due to uncomplete wiring due to the removed standard stereo?
help greatly needed
Before putting the aftermarket stereo in, the clock and cig lighter went off when the keys where out
the stereo turns off when keys are out because the fuse i have it plugged into for 12v is only live when ignition is on
