Hi All ..
Wondering if someone can help .. a couple of weeks ago I was fitting my Bike Carrier to the rear Tailgate of my 2011 RX450h and stupidly pulled the door closed instead of pushing the button to do it automatically .. I had only pulled the Tailgate partly down when suddenly there was a loud bang and from then on each time I closed the tailgate I had to do it manually .. as the button to close just wasn't working anymore so I figured something had broken ..
Then 5 days ago I go to close the Tailgate and just out of long term habit pressed the Close button and hey presto It closed and has been perfect ever since
Bear with me here  ..  I now notice that when I select reverse gear to back into my parking space I have a clear picture of what is behind the car but most of the reversing guide lines which appear on the Dashboard Display have disappeared .. i.e. the Yellow guide lines and also the Red line which tells you your getting too close to an object and which works in conjunction with the audible Beep .. all gone !!
All I have is an occasional Green guide line and sometimes a Green box guide on screen .. no audible warnings anymore
Visual Inspection of the Camera shows nothing wrong .. Parking sensors are definitely in the On mode and I haven't had a bump of any sort
Could the Tailgate stopping working and guide lines disappearing just be a coincidence .. or perhaps a computer software glitch or maybe a hardware malfunction
Any theories / fixes / suggestions would be most appreciated
Cheers Gilbert
53 minutes ago, Gilbert Fudpucker said:
Hi All ..
Cheers Gilbert
I am sure the tailgate problem is not related. There are on the reversing screen small boxes at either bottom corner. From memory the left hand box if touched adjusts for parallel or car park box parking, and the right hand box gives options for different screen line setups.
John.
Hi John ..
Thank you soooo very much for that and your super quick response .. I have just been out to the car and put the screen all back as it was .. brilliant 🙂
Never ever noticed those little boxes let alone knew you could change the settings and quite frankly don't even know how I did it in the first place but thank you .. i'm very grateful for your input especially as I was seeing a visit to Lexus and pound notes disappearing into their coffers
Cheers Gilbert
1 hour ago, Gilbert Fudpucker said:
Hi John ..
Cheers Gilbert
I'm happy you now have it sorted. Helping each other where we can is what the forum is here for.
John.
Yes .. couldn't agree more .. forums are amazing places with a wealth of experience and knowledge
Thanks again Gilbert
