Sc430 amp
messi
Hi
I wonder if anyone can help, I'm sending my amp to a specialist in Edinburgh to repair, it's from a 2001 sc430, but my question is, is the 2001 ls430 amp the same as a 2001 sc430
If I was to replace the amp with another, what one could I use? And where will be able to get the connectors from to plug from the amp to the plugs in the car?
I've sent a reply to your PM. It's not a simple task.
If you are serious about swapping the amp it might be best to consult a good car audio supplier / installer. It will require a line out converter or an amp that can take speaker level inputs. I might suggest looking at say a JL Audio amp but there are so many different amps out there at various budget levels. They can recommend a good quality flexible amp and harness to suit your needs, advise on replacement speakers, etc.
Alternatively I dare say a thorough search of the on-line breakers might turn up a good spare ML amp for less than £200.
Hi
I've already joined lexus World couple of years ago.
I've got an amp now, bought it for £50 and all is working now although I may want to replace the rear sub
