Door Trim
crabbers
  • 1 month later...
Hi
I've just had the same problem, on a '93 GS300 not sure if it is the same, but...
I had to pull out the light in the door (just pops out) behind which there is a big screw / bolt.
Then you have to remove the ash tray / elec window button assy. there is a clip at the rearmost part of the assy, which will pop out (lift vertically), again behind this is another screw / bolt.
The rest is fairly simple and obvious....undo the screws you can see and pop the trim off, the only thing that's tricky after that is the bit at the top that touches the glass, but you'll work it out.
Don't suppose you know where you can get a new motor contact for the motor?
Lexus want £282 for a new assy... the contact looks like is costs 1 pence if that.
Gary
