I have been given so many different stories regarding conversions for imports!!
Has anybody had the T.V. or Sat/Nav converted? And at what cost and where?
Help would be most appreciated. This converter ( NTSC/PAL) on will it work on Lexus models?
Any help or advice would be much appreciated.
Regards Terry
If you have a TV then the tuner will need to be changed as it will be a NTSC one and not compatible with broadcast transmissions in the UK.
If you want to feed a signal into a Sat Nav / TV screen then the second converter on the URL should work. You require an RGB signal to drive the screen.
Regards Terry
Read with interest this post on the NSTC/Pal convertor. I also have a Jap import Harrier with the same problem.
Anybody managed to fix/convert the Sat Nav problem on the Jap Imports.
Regards Pete
