Rear Parking Sensors
Just completed this. There is no need to remove the bumper at all. All you have to remove is the trim to the rear of the boot loading bay and the cover that goes over the rear light cluster (to one side only)
If you have a look at this picture you can see the position of the sensors.
Just run the cable over the bumper irons otherwise the cables will get a bit close to the rear silencer at could melt. Its quite fiddly but can be done. I then drilled a hole in the top of rear edge of the spare wheel well (which is why you have to take the plastic tril off) and fed the cables through and placed the connector box below the rear light cluster. Once all the panelling is back on, nothing is in sight.
Good luck
