Things to change at 100k
2006 RX-300 (Harrier with the 2.4L 2AZ-FE).
I'm at 94k, what things should I start thinking about changing pre-emptively? Plugs obviously but what else? Is it worth changing the water pump, radiator, hoses.. what else?
Thanks,
Mark
I also changed the transmission fluid as I tow but unless its not cherry red I wouldn't worry. Plugs are a sod use iridium 100k change interval water pumps are pretty long lasting if correct coolant is used.Toyota llc is available at a reasonable cost of the bay better to use that than some generic brand.Check the diff oils for some reason my rear diff oil had emulsified a bit , not enough to worry about but changed it anyway.
