best obd scanner is200 year 2000
On my RX I use a VGate Icar2 with Hybrid Assistant because I drive a Hybrid, but for a car with thermal engine there are other good apps, like Torque , Dashcommand or Carista, but my OBD Bluetooth interface is NOT the best even it works well; the main difference between interfaces is the data flow speed, so you have to decide if you need such a fast one or not accordingly with the use you plan to do, another difference is the presence of a switch to enable/disable it to avoid to disconnect it when not in use.
If you like to have a fast interface you can give a look to some ones suggested in Hybrid assistant page: http://hybridassistant.blogspot.com/p/obd.html
(Hybrid Assistant is a free android app developed by voluntary people to help understanding and optimizing hybrid cars )
