Vsc and abs lights
Is any one able to tell me if there is away to turn off or rest them , with any sort of ignition on/off procedure, also air suspension will lift from neutral to high but won’t go back down , any help much appreciated, it’s on a 2004 rx300 se-l
The answer is probably not, because the faults will come straight back and illuminate the warning lights again. You'd need to find out what is causing the warning lights to come on and fix the fault before the lights will stay out permanently.
I'm pretty sure ABS/VSC errors are one of the type of errors that come back immediately, unlike powerplant errors that take a couple of heat cycles of the engine to come back. So clearing the code is no use because it will come straight back as soon as whatever is causing the issue Is sensed by the ABS system.
It may be the suspension that is causing the lights to come on. You'd need to hook the car up to a diagnostic terminal to see what error codes are being flagged so you can see what is causing the error.
