autel tpms sensers
a13bhw
hi,can any one help please,bought a set of 4 autel tpms valves /tyre.pressure sensors. and a maxi pad /autel its recognized all the sensors and given a code number for each one and theyre all working,but car still does not recognize them,   not sure how to program them into car and what scanner/programmer to buy,HELP anybody know.the car is a 2006 lexus gs 300,
You need a program like Techstream to program the serial numbers into the car, but there are TPMS monitors on the market that use the 433 Mhz frequency, and the UK frequency is     315 Mhz so please check the ones you have are the correct frequency. The wrong ones will not work.
John.
2 minutes ago, a13bhw said:
hi,mine are 433 MHz,so ill take a look at techstream thank u very much.brian
Return them to the supplier as they will not work and are not suitable "or even legal" in the UK. They are for use in the USA.
oops bit late now,fitted to car,didnt know that,i asked autel and they answerd these are the ones for your car,well ill go ahead with techstream anyhow.give it a try.these bloody tpms valves are a bit senseless if you are a proper driver u check the tyres anyway,and if u get a puncture you generaly know about it,ok thanks again.
28 minutes ago, fred81 said:
are you sure about this? 433mhz is the UK/Europe frequency with 315mhz for USA?
Yes I am sorry for any confusion I have caused in the above posts. I have made a mental note to check information as I am obviously subject to senior moments.
John.
