Those Things On The Back Wheels
You know the "drum" thing which is a part of the back wheel (excuse my non jargon desc!!!). They are slightly rusty.......is there a speacial paint or a normal paint you can use to tidy these up????? Ive just done my back calipers bright red, and I want the whole lot to look sweet.........
cheers all :zee:
this might even be a replaceable item from lexus under warranty
depends on the age though
if you do use hammerite make sure it is fully dry before putting your wheels back on
i used the smooth hamerite in a spray version, still looking good nearly a year later
If im to paint em........what colour you think will work......Ive a Granite Sky, The calipers are red ( which look bluddy mint )
Come on Arteeeeeeests
Silver.... go well with the wheels then.... i used Hammerire smooth paint...
I have had almost new ( 4 weeks old) go rusty.... best tojust paint them IMO
I had mine changed under the warrently rather than paint them. When these go off too (as they probably will!) I may paint them black to match the calipers. If not then silver would look good.
