Hey everyone,
I hope you are all staying safe and keeping well in Self Isolation ?
I wanted to share a video of my IS 250 from when we were allowed out ūüôā
I bought the car earlier this year and have only covered a few hundred miles on it (due to the global situation)
Ill leave the link to my car and I hope you all enjoy and stay safe!
Thomas
Have you discovered that the keyless entry is operated by touching the inside of the pull handle handle and 1/2 second later the doors unlock and then pull the handle?
If you try and pull the handle immediately you end up having to pull a second time like you did i the video.
Also, have you discovered the speedo can be programmed to change the backlight colour at different speeds?
Does yours have the rear electrically operated blind?
Only the SE-L model has the electric rear sun screen ( it's not even fitted to the ISF model )
The SE-L is easily identified by the fact it is ( again) the only model to have wooden panel inserts in the cabin trim ( and it is real wood, highly lacquered and supplied by Yamaha, the Musical instrument maker not the motor bikes!)
So unless someone has fitted an electric rear sun screen ( and in my opinion it would be major surgery!) then it has not!
paul m.
I assumed his was the SE-L as it had the reversing camera, Sat Nav and ML stereo but i suspect, thinking about it, they may be a part of an upgrade package.
The model designation of car can be found above the Nader pin on the off side ( Drivers ) 'B' pillar.
