CTEK battery charger & GSF
With the current climate and our businesses shut, our F, like many others will not be getting much use. I have purchased a CTEK MXS 5.0 charger  and just wanted to double check how others have wired their chargers up. The GSF manual advises to connect the +ve to the positive Battery terminal and the -ve to an unpainted metallic point when trying to jump start the car. Is this the same principle for the CTEK  or can I wire the +ve to the +ve and the -ve to the -ve?
My F is wired to the positive and negative of the Battery. I'm using the comfort connector with the indicator. Been using this method since having the F and no issues so far.
3 minutes ago, Arqum said:
My F is wired to the positive and negative of the battery. I'm using the comfort connector with the indicator. Been using this method since having the F and no issues so far.
Thank you!
