6x9 adaptors ??
R32crew
Hi guys...
Im new on here so don’t know if I’m posting in the right sections...
I need some help on where to buy some speaker adaptors to fit my CT200H
Ive bought some 6x9 speakers to go in the front doors but they need adaptors  but I haven’t a clue where to get some...
Would be much appreciated if anyone knows...
Cheers...
Hi Umar and welcome to the LOC.
Sorry I have no direct answers for your question but maybe a local car accessory shop or Hi -Fi specialist may be able to help you source some.
Have you already checked the space in the door they’re normally pretty crammed in there with the central locking, door ECU and window mechanisms.
Hi
Hi mate
Thanks for your reply.
yes I’ve checked the space the speakers are located quite far down the door they clear all the wiring etc.
I can get a set of spacers but they from the US & will takes 4 weeks to come so I thought I’d see if any UK stockists has any...
1 hour ago, stormchaser said:
You can make them yourself out of MDF.
Hi
yes iv searched the net quite a lot can’t seen to find them anywhere for the CT200h.
I bought some MDF yesterday will be making them my self on weekend 👍
Hi guys
An update on my speakers
I made some brackets myself out of 9mm MDF board...
First time I ever made anything out of MDF lol not perfect but they do the trick.
The only issue I have now is the sound isn’t all that good... 🤔
The treble is good but the bass is crap 😔
Ive installed JBL’s stage 2. They are 420w & 70w RMS on each speaker.
Thats total power of 840w & 140w RMS.
They should have a good sound but they don’t sound good at all ☹️
i would match the output of the audio to a speaker that has
the same / similar nomimal rating as the nominal rating is
where the speaker can be run all day and will sound the best,
if you use a speaker with a higher nominal rating you will
under drive the speaker and it will under perform
likewise if youhave a speaker with a lower nominal value
you will probably damage the speaker over a period of time
due to over driving the speaker and making it work harder
than it likes.
regarding your speaker adapters did you use silicon between the adapter ring and the door panel
as you need to make an air tight seal between the two and the same goes for the speaker to adapter,
between these pieces you could you the white foam type material that you find around a tv / pc monitor
to protect the screen this will help to create a seal, a speaker needs to create pressure in an enclosure
i.e. inside door... if this pressure escapes on the front side of the panel this maybe a reason for poor sound quality,
you could use dynamat behind the speaker on the door skin as this will stop the panel from resonating ,
as a cheap option you could use some self adhesive flashing on a roll as its dense and will stop the door skin
from vibrating.
from vibrating.
Hi mate.
Thanks for your reply No I didn’t seal the speakers in
Maybe that’s why they don’t sound good..
I just made the brackets & screwed them in
the original adapters will have a rubber seal or some foam
to make an airtight seal against the door panel and stop water ingress
to make a seal you can use anything as long as it can be compressed
so it can confrom to the profile of the door panel
from vibrating.
Hi mate.
I’ll give it a shot at the weekend I’ll try to seal the gaps let’s see if that helps..
One other thing I couldn’t find out which speaker wires (coming from the car ) is positive and negative.
The Front Right speaker had Green & Brown wires.
The Front Passenger side had Pink & White wires...
Any idea on which is which please...
if you have the original speaker and know which wire went to which
terminal on the speaker get a 1.5v or a 9v Battery
and connect directly to the speaker , you will see the speaker cone move
either inwards or outwards when the speaker moves outwards
make a note of which terminal on the speaker is connected to the + of the Battery
obviously the positive wire goes here.
here is a pictorial of the headunit & speaker wiring no colour codes though
the condenser is a crossover so you will only ever get high frequencies
to these cables.
to these cables.
Thanks for all the help mate really appreciate it 👍
I’ll get the door cards off when I get some time I’ll seal the speakers in & do the Battery test that you mentioned.
Hopefully that should solve the issue.
Cheers.
