Hi all I had the centre console for auto transmission out to change few bulbs. After changing the bulbs started her up and the auto transmission is stuck in P. My brake pedal when pressed doesn't allow it to shift gears I have to hold the Interlock button to shift gears. I think I must have but a spring for the lock somehow wrong also can't get my key into ACC or OFF have to disconnect Battery to get key out. Can someone guide me how to put this spring in. Or even better a photo of another one installed correctly. Highlighted is the two bits that I think I've put in wrong. Shift lock release link and shift lock release spring..
Checked all fuses there all good. This happened when I was putting it gear shift assembly back together. Key is stuck in only can remove if Battery off..
