Bicycle tyre pressure?
PCM
Yes, if the valve is the same. Just go slowly as the amount of air is obviously much less than a car tyre.
What type of bicycle is it? Normal road bike should be around 50 to 60 PSI, and a mountain bike around 40 PSI. A road racing bike is normally around 90 PSI but that wouldn't have a car (Schrader) valve. There is normally a max. pressure rating written on the side wall of the tyre.
Thank you, Colin.
It's a https://www.pashley.co.uk/bikes/bicycles/parabike.php
I shall look on the tyre as well.
