Preventative maintenance
What stuff should RX owners do as preventative maintenance? Is it a good idea to change the thermostat, radiator cap.. any other small cheap cooling system components that could cause overheating if they fail?
reading earlier about the RX300 early one's having a prone under section that rots out ..........  maybe check all that out to prevent anything untoward leaping up and causing grief
Mine's a 2006, not sure if that counts as early. There were some rust spots picked up on its 2019 MOT which I had dealt with, this year's passed with no advisories. I'm planning to deal with some spots on the bonnet soon so when I get around to that I'll have a look underneath as well.
Yes, mine had to have a bit of welding (MOT ).
Cost about £150 ...
