is250 2008 spare key fob and passenger puddle and red light(s) not working
Hi
My spare key fob and passenger door puddle and door red light are not working.  So far tried putting a Battery in the key fob. Not sure where to start with the door. Any advice would be muchly appreciated!
With the key fob firstly make sure the replacement Battery is good, if you have a volt meter check it with that, if the fob has an LED does it flash when a button is pressed?
Regarding the door lights are your courtesy lights working as they are generally all connected so come on together. Blown bulbs would be my first suspicion which may involve the door card being removed to access the fittings.
