Since I bought the 430 its felt so loose on the front end and wanders a bit as more than sure one of the previous must have wound the BK coilovers to rock hard wearing all the standard suspension out, its now running at its waftiness, I thought I'd replace the whole front end with Febi components and tighten it all up again. All done and now re-aligned perfectly on a Hunter... tight as a drum...a few creaks as it settles and after a couple of 100 miles I'll get it re-checked and all tightened. I had to buy new Camber bolts from Lexus at £35 a side (bolt washer and nut) and cut the old ones off....also had a faulty ABS sensor after getting it back together so a breakers supplied a new/used one..... here's the pics.... Well worth the £££
A lot of work and expenditure involved there. Did you use all OEM parts.  Hope it drives straight and true.
I used Febi parts which are as good as if not better than OEM... it's tight and straight as an arrow now...
Must be tough getting all the nuts and bolts off!
I replaced the shocks on my 55 GS300 and had a few choice words with all the seized and rusted nuts and bolts!
Wish I have the place ( 2 post lift ) and time to rebuild the suspensions - both front and rear!
The bottom arms and bolts had to be cut off and took nearly 3 hours for both sides as bolts seized inside bushes..... absolute nightmare!!!
400 miles in and all good as gold.... re-checked alignment and slightly out after settling, all good now - next up cut out exhaust joints and replace next week as chuffing a bit....
The car has 86k miles now, what sort of value does it have?
Nice work, I take it you have the full garage facilities and not just a trolley jack and axle stands and working off the floor?
