LS430 Reversing Camera removal
The reversing camera on my 2005 LS430 is not working. I have bought a scrap OEM replacement (which works fine when connected to the existing fitting). I've managed to removethe boot liner and can see the camera fittings but can't see 69BC9789-4161-463E-82E1-ED769A12277E.thumb.jpeg.76a1b51304f48e2067b4065ef973edb4.jpeghow they work. There are two black plastic ferulled covers which look as if they may screw off but which don't want to move.  There's also smaller clips near the camera body itself which look straightforward. Photo showing black ferulled thingie attached. Can anyone advise please? Thanks in advance....
You'll need to squeeze the plastic clips you see in that area which I've circled below with pliers to remove the panel on the exterior of the boot (the one that has the boot release button and the number plate lights). It might not be obvious but it is a part that can be removed.
Removing it will expose the bolts for the rear camera. Those two black plastic covers you are referring to are where the bolts holding the camera get secured into.
