2008 lexus gs 450h engine mount
Hi guys , i try for last week or so to find those parts but i have no luck at all , maybe someone can help me with ...
I think the part name is engine mount or gearbox mount but i will attache some pics just to be 100% sure
thank you
17 minutes ago, Britprius said:
From your pictures that appears to be the front lower suspension wishbone rear mounting bush. This is nothing to do with the engine or transmission.
John.
Thank you John for the reply , but what i really need is where do i find them to buy ...sims to be very hard to get them thank you
If you search eBay you will find many more. You can buy just the bush without the alloy housing, but you then need a press to push the bush out, and in.
You can also buy uprated versions that use a plastic instead of rubber but these can transmit more road noise.
John.
29 minutes ago, Britprius said:
If you search Ebay you will find many more. You can buy just the bush without the alloy housing, but you then need a press to push the bush out, and in.
John.
Thank you again for you help , wish you all the best
regards
These are lower control arms bushes and us LS430 need to replace them once we hit 130K plus miles
Paul Frost sell them for the 430 complete with the carriers so all you do is undo the bolts and swap over - barely takes 5 minutes
If yours are soft that you can push your finger in then they will need replacing
https://www.ebay.co.uk/str/lexussparesdirect
Thank you for your reply , but i find my parts already , also i was interested in parts for GS450h not LS430
thank you again
These are quite famous in the 2nd gen IS community - and the 3rd gen GS happens to be much the same underneath.
A common upgrade is to install the RC-F/GS-F bushings, or to completely swap them out for polyurethane ones - whether it's due to front tire wear (softer bushings = more dynamic toe) or for steering precision/feel. I went with GS-F on my own.
John.
Hello again , any chance to know the name of those and where i can buy them , i assume i have to buy all that part ..
thank you
16 hours ago, Lwerewolf said:
https://lexus-europe.epc-data.com/gs450h/gws191r/5066/chassis/4802/
Where to buy - from what I've read, there are quite a few Lexus dealers in the UK that are reasonable, plus the site sponsors...
https://www.lexusownersclub.co.uk/forum/forum/99-traders/
Found  them here , don t know about shipping yet , also thank you so much for help , wish you all the best
https://www.buycarparts.co.uk/search?keyword=Ball+Joint
