Mike
Completed conversion, I have reducing the spring tension by 20mm, still a fairly hard ride, What did you reduce the tension by?
Chris
Hi Chris I started by takeing tension off then winding it up by hand till it got tight , then puting the second lock ring up to the first one and then wound the top one up until the the supplied spanner fits between ( about 4mm) then locking the lower one, what height have you set all around the car
From ground to top of wheel arch the car is sitting at 31 inches all round.
Chris
