My Is200 Se
LSD and TC are different things. As I understand it TC is an electronic aid (reducing drive power if it detects that a wheel is spinning) whereas LSD is mechanical (prevents one wheel spinning freely if the other wheel has grip).
Only the IS200 sport has LSD.
I'm guessing that "snow mode" is just TC but with the sensitivity just turned up a couple of notches!
The SE does NOT have LSD as standard.
If you wanted to be sure it hasn't had one fitted after ....
jack up and support rear of car - both sides ....
rotate one wheel in forward direction...
If LSD is present, wheel on other side should go the same way.
If no LSD, the wheel on the other side will rotate the opposite way.
