Map sensor ? code p0110
Hello.
I have a code p0100 p0110 and p1651.
The vsc is lighting and the engine revs only to 3000 rpm.
The triangel is flashing.
I orderd a new MAP sensor and reset the codes but the same code appired.
The volt is 5 on the cable and i don´t know what to do.
Any one having the same codes ?
P1651 is quite common on the 430 engine. It is the VSV that controls the ACIS that fails. It is a pain to replace as you need to remove the intake manifold to get to it - make sure all the wiring and vacuum hoses are in good condition whist you have access.
Not sure why the other two codes have come on - I've seen another report of all three codes coming on at once but I believe the VSV is the main issue.
3 hours ago, Benni Johansson said:
Hello again Collin.
I took of the upper inlet mainfold I did not find the valve, is it under the lower inlet or where is it lokated?
It's on the bottom side of the lower inlet - the component diagram within the thread that I first posted shows the location (COMP.PDF).
