Zero point calibration
Delp
Lexus GS mk2 after a wheel alignment does the GS have to be zero point calibrated? I know one member said it does but what's the procedure if you haven't got scanner tool. As when I took it to the wheel alignment place they plugged it in but couldn't do it as scanner wasn't recognising it but ended up with ABS and VSC lights on which had to bridge pins in DLC1. Any thoughts
