Adhesive for rear screen bottom trim LS400
Hi .
I dont know what adhesive or sealant to use to attach trim to the body? I mean the black trim that sits between the rear screen and  boot lid  , it has around 6 fixings and they put a smear of some sort of adhesive the hold the wing shaped plastic down.
Any ideas?
There are a multitude of different sealant you could use any sealant you apply may have to come off again should you need to replace the windscreen .
Sikaflex make a marine grade black sealant that is waterproof and is under a tenner Reference ; Sikaflex 291i .
