Rear Windscreen Replacement Advice
CypressPhil
Evening all, Forum noob here looking for some advice from your collective wisdom.
I have an IS300h in F Sport trim (65 plate) that I’m really pleased with... however, it has a slight leak at the rear windscreen (verified with some soapy water and an airhose). I’ve spoken to a local windscreen fitter who advised they could remove and re-bond the screen for £65. They then went on to say that although they have a good success rate of removing rear screens, there is a chance that it could crack on removal.
On speaking to my insurer, I wouldn’t be able to make a claim on the windscreen policy if it were to break on removal. It’s bizarre that the most cost effective solution to my problem is for a local hoodlum to put a brick through it.
Has anyone got any experience of rear screen removal on the IS?  I’m just trying to gauge the likelihood of the screen failing on removal. If it were to fail, does anyone know how much a rear screen actually costs on one of these?
Many thanks in advance for your assistance.
