Window Trick
Maybe this is a commonly known "thing", and maybe not.
Sometimes after you disconnect the Battery for any reason, the window buttons on the driver's door do not operate one or more of the other windows.
Turn the ignition on, go to the non operating window and open it with the button on that door.  After it is fully open, keep holding the button for a couple of seconds.  Then close the window and after it fully closes, keep holding the button for a couple of seconds.  You might have to do that a couple of times, but usually the buttons on the drivers door will work again.
I hope that helps someone.
Sometimes after you disconnect the battery for any reason, the window buttons on the driver's door do not operate one or more of the other windows.
Just make sure your partner isn't trying to take a 'Selfie' on the motorway at the same time - - or there could be a 'falling out'!
