Help
Icefoxx78
Google is your friend.
Entering "Lexus P1349" (without the quotes) into Google brings back lots of results, none of which seem to indicate a cheap fix.
It looks like P1349 is something to do with the Variable Valve Timing.
43 minutes ago, Icefoxx78 said:
Said if can find part will fix it
You can't just "find the part" without proper diagnostics first.
The error code (in your case P1349) is just a starting point for more investigation.
