Hidden Tire-valve
PhoneDrome
Anyone know if you lose air pressure connecting and disconnecting to these - like the look of them but I'm a bit fussy on pressures ...
  • 1 month later...
Want to buy some hidden valves for my new Alloys. Does somenaody know the correct diameter of the hole for the valve?
There are two different valves available. 8mm and 11mm dia. Which is the right one for 8x18-alloys? I'm not sure.
Hi the invisible tire valve is used in rim hole of 11.3 mm /.453", which is instead of TR413/TR414...
The other smaller type is for 8.3mm/.327"
email: hzwtox@sohu.com
