2016 rx450h phone mirroring
Hi I can’t seem to find a definitive answer on this.
there are many mirror and airplay kits that you can install or have put in properly that require dash remove and a small pc in the glovebox.
however, is it true for the rx that you can use a 4 pole aux jack into the aux plug and mirror your phone via a hdmi converter?
this would be a much easier and cost effective solution!
ta
I made some experiments about it, and the main problem is that if you use the AUX plug it works fine (provided to make the right connections) but video disappears if car is moving. There is a solution (from some russian interfaces) but I suspect it is not legal because you can have on video screen some distractions: it' s the same reason for having only some selected apps on android auto and not a simple mirroring of all you have on cell phone or tablet.
A simpler way to bypass problem is to use directly tablet and cell phone sending only audio to car audio system.
