IS250 clutch replacement - Tips, things along the way
CallumH
Hi all,
I am replacing the clutch in my 2006 is250 with a spec stage 2+ and spec solid flywheel very soon. Parts are ordered on route from JM imports. Very helpful guys if anyone needs anything, worth contacting them.
Just wondering if there is anything worth replacing along the way that I should order now? I dont want it stripped down on a ramp and then find out theres a common thing worth doing and miss the opportunity to replace them with the box being out.
Thanks for any advice
On 10/11/2020 at 9:35 PM, CallumH said:
Hi all,
Have you also thought about doing the clutch delay valve delete? This guy on the US forums (Jeff Lange) did this and said it felt much better after
