VGRS and ABS lights, car won't start
abtx
I've driven a bit yesterday and got the VGRS and ABS lights lit up together with loud long beep. Today this happened right as I started the car.  I turned it off, and couldn't start again. I played with the button and eventually things slowly died out. What would make sense to do to diagnose? Jump it, replace the Battery if the jump didn't help?
24 minutes ago, LexIS200Sport said:
It could be that your 12V battery is on its way out? Mine is a 450h but I do get the VGRS error if my 12V battery is very low on charge.
I'd certainly try a fresh 12V battery as a starting point.
Hopefully it is not alternator. Had the Battery light flicker once before, might have been an indication of Battery running out. Battery was last replaced in Sept 2014 I guess that' pretty old.
