Bonnet vent
Just got 2015 RCF in great condition from main dealer but have noticed the bonnet vent seems slightly skewed. The bonnet it a perfect fit,shut lines perfect, not a sign of repair or damage. The vent, including the raised shaping of the vent looks a little tilted, the right side very slightly nearer the windscreen, only by a few mm. It's hardly noticeable but once you have seen it it's always there. Is this normal, has anyone else come across this?
Welcome Shedman,
There is a separate forum for the F cars (ISF, RCF, GSF). You may have more chance of a reply on there.
I've not noticed a difference on mine. I'm almost afraid to look in case I can't unsee a tilt
19 hours ago, Shedman said:
.... looks a little tilted, the right side very slightly nearer the windscreen, only by a few mm. ....
Have you actually tried measuring the distances, perhaps with a non-scratching cloth roll-up tape of the type used by dressmakers, in order to objectively prove or disprove?
