XK140 12 Posted December 1, 2020 Share Posted December 1, 2020 Routine oil level check on my (new to me) RC F. It seems impossible to make out where the level actually is because oil appears not only up to the top level mark but smeared way beyond that...or is it that that the true level because it has been overfilled? Not sure what to think ??? Quote Link to post Share on other sites
XK140 12 Posted December 1, 2020 Author Share Posted December 1, 2020 Hmm...a brief internet search reveals many complaints in the US of the oil being overfilled. Quote Link to post Share on other sites
BillNick 54 Posted December 1, 2020 Share Posted December 1, 2020 Where was it last serviced do you know? Any warranty? Quote Link to post Share on other sites
NemesisUK 1,628 Posted December 1, 2020 Share Posted December 1, 2020 You did wipe the dipstick before replacing and then removing again to check? Quote Link to post Share on other sites
PRT68 99 Posted December 1, 2020 Share Posted December 1, 2020 I thought I had that problem with my ISF when I bought it. A quick look in the manual said to to only check the oil level 5 minutes after turning the engine off. This then gave the correct reading. Is the RCF the same? 1 Quote Link to post Share on other sites
BillNick 54 Posted December 1, 2020 Share Posted December 1, 2020 Indeed most oil level checks, I have always performed cold.....that way you know it has all fallen into the sump. Perhaps checking it too early, or warm, might prompt someone to top it up unnecessarily..... Quote Link to post Share on other sites
NemesisUK 1,628 Posted December 1, 2020 Share Posted December 1, 2020 From the RC-F handbook With the engine at operating temperature and turned off, check the oil level on the dipstick. ■ Checking the engine oil Park the vehicle on level ground. After warming up the engine and turning off the engine, wait more than 5 minutes for the oil to drain back into the bottom of the engine. Holding a rag under the end, pull the dipstick out. Wipe the dipstick clean. Reinsert the dipstick fully. Holding a rag under the end, pull the dipstick out and check the oil level. Quote Link to post Share on other sites
XK140 12 Posted December 1, 2020 Author Share Posted December 1, 2020 Thanks for all the replies. I’ll do another check with a warm engine as stated above. My last check was this morning with the engine stone cold. I’ve been checking and changing oil and filters for more years than I care to remember so I think I know the basics. My feeling at the moment is that Lexus Cardiff overfilled it at the service last June...not possible to prove of course. I did see a remark on the internet that this engine takes a long time to drain,and techs don’t wait then put in the official oil quantity thereby overfilling. The correct method,to me anyway,is to fully drain and then refill with the official amount less one litre,getting the level to the bottom of the stick and then gradually topping up. Quote Link to post Share on other sites
XK140 12 Posted December 2, 2020 Author Share Posted December 2, 2020 OK,check today in the prescribed manner. The distance between the high and low marks on the dipstick is 2 cm. The oil level sits at,by coincidence,as near as I can say to 2cm.ABOVE the high mark. The handbook,unlike on other cars,is not helpful in that it does not tell you the quantity of oil that equates to a top up from the low to high mark. An educated guess by me would be one litre,and from that I would conclude that the oil is overfilled by one litre. The next question is should I take any action...on a small engine that amount would be a lot,but perhaps not significant on a 5 litre engine with over 9 litres oil capacity? Quote Link to post Share on other sites
NemesisUK 1,628 Posted December 2, 2020 Share Posted December 2, 2020 From the handbook (page 441) Adding engine oil If the oil level is below or near the low level mark, add engine oil of the same type as that already in the engine. Oil quantity (Low → Full) 1.5 L (1.6 qt., 1.3 Imp. qt.) I would use an oil siphon and remove the excess oil before it possibly contaminates the CATs or becomes aerated due to crankshaft lobes contacting the higher oil level.. Quote Link to post Share on other sites
XK140 12 Posted December 2, 2020 Author Share Posted December 2, 2020 12 minutes ago, NemesisUK said: From the handbook (page 441) Adding engine oil If the oil level is below or near the low level mark, add engine oil of the same type as that already in the engine. Oil quantity (Low → Full) 1.5 L (1.6 qt., 1.3 Imp. qt.) I would use an oil siphon and remove the excess oil before it possibly contaminates the CATs or becomes aerated due to crankshaft lobes contacting the higher oil level.. Thanks for that,sadly I have not got a “handbook” but only the far shorter RC F User Guide. I agree some oil needs removing.I don’t have an oil syphon but I do have a competent nearby garage who can do it. 1 Quote Link to post Share on other sites
NemesisUK 1,628 Posted December 2, 2020 Share Posted December 2, 2020 Download yours from here.. https://www.lexus.co.uk/owners/about-my-lexus/manuals/ Quote Link to post Share on other sites
