Shane34gs300 0 Posted December 5, 2020 Share Posted December 5, 2020 Hi all I own a gs 300 sport. Everything electrical worked until yesterday morning. I've searched on the forums and looked at the fuse box layouts but it's confusing as some of the fuses operate other items which still work. List of faulty electrical items as of yesterday morning Front door locks, key fob does not make these work. However rear unlock and lock. Door lock Control driver door does nothing. Windows work fine. Wing mirrors no longer move with the control. Dash does not show lights are on or fog lights, did before. All the other warning light show on ignition on. Steering memory does not work now. Button to move the steering wheel works fine. Seats work fine, but never had memory seat set up/used. Touch screen display Radio works Map works Sat nav works Climate system function are not able to be selected, the button on the consol do not light up. The climate was set to warm and this still continues to blow warm air. I've checked the fuses in the engine bay and a some of the interior passenger and drivers foot well. But finding information about which does what is frustrating as all the info online means I need to download and sign up to something. I'm wondering if it's some sort of interior type ecu module that has failed. Quote Link to post Share on other sites
Shane34gs300 0 Posted December 5, 2020 Author Share Posted December 5, 2020 Only topic I've found remotely close was down to a gateway ecu. However not sure that even fixed the guys issues. Is there any other interior control units/ecu that saves the memory of certain items, like steering wheel positioning, climate settings. Quote Link to post Share on other sites
cruisermark 627 Posted December 5, 2020 Share Posted December 5, 2020 I would check the Battery - sometimes a failing Battery produces numerous unexplained faults Quote Link to post Share on other sites
Shane34gs300 0 Posted December 5, 2020 Author Share Posted December 5, 2020 1 hour ago, cruisermark said: I would check the battery - sometimes a failing battery produces numerous unexplained faults Interesting as it was extremely cold that night covered in an inch of snow. I'll swap it for my is300 battery Quote Link to post Share on other sites
Shane34gs300 0 Posted December 6, 2020 Author Share Posted December 6, 2020 On 12/5/2020 at 6:09 PM, cruisermark said: I would check the battery - sometimes a failing battery produces numerous unexplained faults So the snow had melted and dripped into the Battery tray, which then I believe maybe have messed with the Battery. Will be testing everything tonight Quote Link to post Share on other sites
TigerFish 250 Posted December 17, 2020 Share Posted December 17, 2020 On 12/6/2020 at 6:55 PM, Shane34gs300 said: So the snow had melted and dripped into the battery tray, which then I believe maybe have messed with the battery. Will be testing everything tonight How did it go? Quote Link to post Share on other sites
