Brechin Slate 163 Posted December 6, 2020 Share Posted December 6, 2020 Hi all I'm selling my is250 but want to do a few jobs first to ensure it's presented in the best possible light. One of my issues is a 4 inch crack in the vinyl above the radio. Has anyone had a similar problem and successfully filled/repaired it? There are various vinyl repair kits on the market but as usual with very mixed reviews. Regards to all. Quote Link to post Share on other sites
markeyszoo 36 Posted December 6, 2020 Share Posted December 6, 2020 Have you considered a dash mat/ carpet at as seen on eBay for £12 ish 1 Quote Link to post Share on other sites
leelacey17 104 Posted December 6, 2020 Share Posted December 6, 2020 I repaired marks / holes around the centre vents in mine before I sold it. I used one of those kits off of amazon. Takes a while to do but it takes your eye off it. Sent from my SM-A505FN using Tapatalk 1 Quote Link to post Share on other sites
rich1068 1,240 Posted December 6, 2020 Share Posted December 6, 2020 Got a link Lee? Quote Link to post Share on other sites
leelacey17 104 Posted December 6, 2020 Share Posted December 6, 2020 Only a picture so should help. Does take a while to build up the layers. Best of luck with it Sent from my SM-A505FN using Tapatalk 2 Quote Link to post Share on other sites
Brechin Slate 163 Posted December 6, 2020 Author Share Posted December 6, 2020 Thanks for the quick replies. I like the mat idea as it's no work and a good result, I'll check the sizes tomorrow. If it doesn't cover the crack on the contours I'll go down the kraftex route.👍 Quote Link to post Share on other sites
markeyszoo 36 Posted December 6, 2020 Share Posted December 6, 2020 Quote Link to post Share on other sites
Linas.P 1,352 Posted December 6, 2020 Share Posted December 6, 2020 43 minutes ago, markeyszoo said: It kind of highlights the potential issue rather than masks it. I guess it is ok to use for yourself if you want to protect the dash, but I would imagine any buyer would be immanently put-off after seeing it, even if there is nothing wrong with the dash. Quote Link to post Share on other sites
Brechin Slate 163 Posted December 13, 2020 Author Share Posted December 13, 2020 Many thanks to leelacey17 for the Kraftex tip. The 2 cracks can be seen in the first pic below and the repair in the second pic. The IPA dried out the vinyl but a bit of post repair care tomorrow should make it look good again. 1 Quote Link to post Share on other sites
Marleez 14 Posted December 13, 2020 Share Posted December 13, 2020 7 hours ago, Brechin Slate said: Many thanks to leelacey17 for the Kraftex tip. The 2 cracks can be seen in the first pic below and the repair in the second pic. The IPA dried out the vinyl but a bit of post repair care tomorrow should make it look good again. Looks good Quote Link to post Share on other sites
