EGR knocking badly
R32crew
Hi guys...
My car has had the knocking rattling & misfiring issues for a few months now...
Now it’s got quite bad my engine light is on when I had it read it said Miss fire on cylinder 1...
Im going to hopefully give the EGR valve & the Pipe a clean on weekend depending on weather...
Does anyone know if I remove the throttle body & clean that too would I have any issues on re fitting throttle body ???
Cheers.
On 12/9/2020 at 11:54 AM, R32crew said:
Hi guys...
Cheers.
I dont have a ct200h could it be spark plugs /leads or coil pack? Check camshaft? What's the mileage?
Hi mate.
Me & my friend took apart the EGR yesterday what was meant to be just an EGR clean ended in...
Removed EGR the cooler & the pipes connected. Cleaned out the EGR cooler & pipes with brake cleaner.
Removed & cleaned the Throttle body with brake cleaner.
Also removed & cleaned the Intake manifold.
End result after 6/7 Hrs working perfect job The rattles missing shakes all gone.
Drives perfect now 👏👍
