BLUETOOTH CONNECTIVITY OPTIONS
HI, WOULD LIKE ANY ADVICE ON THE WAY TO CONNECT A SUITABLE BLUETOOTH  DEVICE VIA THE AUX SOCKET ON MY MARK LEVINSON  EQUIPPED IS250
THE ONE THING I OVERLOOKED WHEN I PURCHASED THIS CAR, A MISTAKE I WILL NOT MAKE ON MY NEXT IS/GS I PLAN TO PURCHASE NEXT SUMMER
UNTILL THEN I NEED TO SOURCE SOMETHING SUITABLE
Hi m8. Look on eBay. You'll need a shallow 12v cigarette charger adapter. A 90° USB male to female adapter. Then a Bluetooth adapter. I'll try and put links on your thread but if you look in search on here you should find a thread where the links are there. Reason for the shallow 12v adapter is because rhe best and stealth location for the Bluetooth adapter is in the armrest cubby hole. When the lid is down a normal 12v adapter would foul the lid. Cost will be about £12.
https://www.ebay.co.uk/itm/292074804774
https://www.ebay.co.uk/itm/303642200154
https://www.ebay.co.uk/itm/164201487335
These are what I use in my is250 with ML and it works very very well and I thoroughly recommend these items.
THANKS,  I WILL HAVE AGO & SEE WHAT THE RESULTS ARE LIKE
have a look on the thread below as a few options were discussed. I went with the cheaper option at the beginning with the aux adapter in the armrest but wasn't happy with the sound quality and then upgraded to the adapter that plugs in at the back of the radio and shows as an extra CD magazine for £35 - so not crazy expensive. Only downside to the latter option is that you need to take out the whole satnav/radio and you may end up damaging the dash if you're not careful.
I've received & tried the components for the cheap option, it works but I'm not happy with the sound quality & mainly it keeps on disconnecting whenever I remove the phone link requiring me to re pair every time whic is apain.
so the search goes on
I use one of these
https://smile.amazon.co.uk/Golvery-Bluetooth-Transmitter-Receiver-Streaming/dp/B01NACN8PY/ref=sr_1_3?dchild=1&keywords=Golvery+Audio+Jack+Bluetooth+Transmitter&qid=1610407618&sr=8-3
Had it fitted since 2019 and has been fine. I don't use it for calls though, I only use it for listening to Absolute 80s on Tunein.
I don't touch it at all, it sits ignored in the arm cubby hole connected to the Aux In and a double USB socket for power. My phone connects as soon as I start the car.
No problems with it dopping out at all. Sound is perfect for a someone like me who listens to 80s music on the wireless whilst driving.
You say you've tried the cheap components. Are they the ones I suggested and posted links for? If so I'm very surprised as mine work perfectly and the sound is superb. But where sound is concerned it depends on what your listening to. For example if I listen to Planet Rock the sound is very good. However if I listen to Radio 1 drum and bass show the sound is outstanding. Yes I have ML.
15 minutes ago, chr15gb said:
I use one of these
thanks, just had a look on the link & I'm gonna take a punt
yes, I bought the exact items however it worked but maybe i gave up to easy as at the time i was in a rush to get it set, I'm still gonna give it another try
On 1/11/2021 at 11:30 PM, chr15gb said:
I use one of these
I purchased & installed one of these & I am well happy, works exactly as described
