"Check BSM system" & warning triangle - 63 plate IS300H
Hi All
I have a 63 plate IS300H Premier, a few days ago I popped into the grocery store, on the way back when pulling into the driveway, I randomly got this error "Check BSM System" with a warning triangle, I turned the car on and off again and have driven a couple of times since then and it has not reoccured.
My car is still under a approved used warranty, should I be raising this? It looks to be relating to the blind spot monitoring but I'm not 100% sure where the sensors are located in this car, due to covid I hardly drive it so the car is pretty clean, purchased it from a main dealer a few months ago and has about 62k miles with full Lexus history.
I'm hoping its a normal error people on here get from time to time, if not I may have to do some more digging đŸ™‚
The Manual states that this warning relates, as you suggest, to the Blind Spot Monitoring system.  As far as I can see, the only recommendation is to refer the car to a Dealer!
The sensors, I believe, are located in the wing mirrors and along the rear of the car.
As it’s still under warranty I would be inclined to do that ASAP.
Edited by LenT
More info
The fact you mentioned you hardly drive your car since covid, I'm going to take a wild stab at the problem, and point you to the auxiliary Battery in the boot. There's a good chance the Battery is on it's way out. All sorts of error messages pop up when the Battery starts to fail.
I can’t help with the error message but earlier this week the dashboard on our CT was lit up like a Christmas tree and car would not start.  Called the AA out,  fault diagnosed to a flat Battery as the car currently is not being used as much as normal due to Covid (was doing a 250 mile, mainly motorway trip at least once a week).  I also contacted my Lexus dealer who advised the following
Run the car in ready mode for an hour, even longer if you can and probably once a week or once every 2 weeks to keep it charged up!
I hope this helps.
If it’s under warranty surely the answer is to get it booked in to a dealership to get it checked out. I would.
take a photo of the message on the dash and email it to your dealer so there's a log of it happening whilst under warranty
and get your car booked in for them to look at it,
maybe contact lexus uk and inform them so they are also aware in case the dealer
can't get your car booked in until after your warranty has expired
you should still be covered then
Not really the ideal solution, for several reasons.  For example, it's not very environmentally friendly.  If the car's on the public highway, and unattended, it would be illegal.  And some say one hour barely compensates for the current used to start the vehicle.
A better solution is to buy a trickle charger.  I bought a CTEK and fitted sets of accessory plug-in connector leads to the Battery posts of both our cars.  Now all I have to do is plug the CTEK connector to the installed leads, turn on the CTEK and leave it overnight to do its thing.
The OP has a hybrid vehicle, no current is used from the 12v Battery to start the vehicle.
48 minutes ago, ColinBarber said:
The OP has a hybrid vehicle, no current is used from the 12v battery to start the vehicle.
Thanks for that info, Colin.  Hybrids are foreign territory to me, I must admit.  Lexus tend to loan me one when mine’s in for service and, to my shame, I have managed to stall them on a couple of occasions!  However, I think the other points are still valid - and two out of three ain’t bad!
But mainly I’m suggesting that in a low mileage situation and especially in winter, an easy-to-use trickle charger is a sound investment.
At least, that’s been my experience.
Agreed. I think I've only done around 300 miles in my vehicle since April and I leave it permanently connected to a trickle charger. But I guess not everyone has the convenience of electrical power near the vehicle.
But I think I'd rather run an extension lead to my vehicle and use a charger once a week for a few hours rather than starting up the vehicle and sitting in it for an hour.
That’s a whole new topic you’ve opened up there!
Thank you for all the replies, if no ones seen this error guess its not that common so i'll report it to the dealer and take it in when Covid figures are looking a bit better as it does not seem like a urgent issue (light has not since that one time).
I do drive the car for 10min every week just to keep the Battery topped up, i've not had any issues "starting" the car but hard to say what condition the smaller Battery is in, longest stretch its been without starting is 10 days but it did fire up without issues.
My only concern is, with my old car (E Class) even though it was under warranty they charged me diagnostics as they could not find a issue so the dealer could not claim under the Mercedes warranty, I was a bit worried about the same happening here if no fault found or are Lexus generally pretty good?
It's not your job to identify the problem, only to demonstrate the symptom.
If you can show the problem (in this case a message on the dash), it's surely up to them to find the issue.
I think Mercedes did you over there. Unless you weren't able to prove any problem or show them an error.
I doubt you'll have this issue in your circumstance, but if you did, I wouldn't be backing down!
I got the money back from Mercedes in the end but it took a lot of back and forth, I was picking up the car at lunchtime during work so had to pay it to make it back in time, Mercedes service was poor most of time in my experience but i've heard Lexus is a lot better but once bitten twice shy đŸ™‚
I've taken a photo of the error message on dash in any case so I will show them that.
Len,
How do you stall a hybrid?
John
11 minutes ago, OldTrout said:
Len,
John
I’ve no idea John.  Which probably explains why I did it again, months later!  I can only think that being a stranger to the hybrid I thought it had stalled and, being at the head of a queue at traffic lights, did the wrong thing.  Whatever that was!
But whatever it was, I haven’t done it again.
The engine is often not running when you stop but that doesn't mean it has stalled. When you press on the accelerator the car will move forward by the electric motor and depending on lots of things the ICE will assist sooner or later.
John
Yes, I think that must have been it.  Note to self: must pay attention!
Ă—
Ă—
