j051 5 Posted January 22 Share Posted January 22 Hi all, has anyone else noticed any occasional popping / crackling noises when streaming music through Bluetooth in the is300h? Mine is a late 2013 model so might be that this is only in the older navigation system models. I am using an Iphone X. it does not happen when I connect through usb. Have played with the equalizer too ( I know it has to be set separately for each audio source ) but that is not it. What tends to help is pausing the music and then continuing to play it again. It might be an Iphone problem but then again it does not happen on other Bluetooth speakers. any thoughts? Thanks guys! Quote Link to post Share on other sites
ColinBarber 2,113 Posted January 22 Share Posted January 22 Premium Nav or standard? Never had an issue on my 2013 model with premium nav and an Iphone (not an X) but I'd normally use the wired connection as sound quality is better. Quote Link to post Share on other sites
Andrew888 114 Posted January 22 Share Posted January 22 Lexus has advised me that if any BT problems, it could do with a firmware upgrade if its available. Worth calling a dealer and enquiring. 1 Quote Link to post Share on other sites
matt8 96 Posted January 22 Share Posted January 22 I have this issue in mine. Sept 2013, Premium Nav. I took it to the dealer and they replaced some hardware, at some great cost they told me, but under warranty. It didn't fix it. I've lived with it since. Just turning the audio off and then on sorts it. It's good for a while after that. 1 Quote Link to post Share on other sites
j051 5 Posted January 27 Author Share Posted January 27 On 1/22/2021 at 7:14 PM, matt8 said: I have this issue in mine. Sept 2013, Premium Nav. I took it to the dealer and they replaced some hardware, at some great cost they told me, but under warranty. It didn't fix it. I've lived with it since. Just turning the audio off and then on sorts it. It's good for a while after that. Matt, are you using Spotify, I may have fixed it by disabling the equalizers in the Spotify app. I’ll keep experimenting though. Quote Link to post Share on other sites
matt8 96 Posted January 27 Share Posted January 27 Google Play Music initially. Now Spotify as of recent. Both the same. Will have a play with EQ though, worth a look. Unfortunately, I've ruled out a device issue, I've used two Android devices and both are the same. Maybe I should try and apple device just to be sure. 22 minutes ago, j051 said: Matt, are you using Spotify, I may have fixed it by disabling the equalizers in the Spotify app. I’ll keep experimenting though. Quote Link to post Share on other sites
