AKH 0 Posted January 30 Share Posted January 30 Hi, My 12v Battery is playing up and I am baffled as to which Battery to go for Eurocarparts suggested a Lion AGM Battery and their website does not seem to have a standard Battery choice for my vehicle Does the car need a AGM? What have you guys replaced your ones with Lexus themselves quotes £148! Regards, AKH Quote Link to post Share on other sites
Brechin Slate 170 Posted January 30 Share Posted January 30 Hi AKH, take a look at this: Quote Link to post Share on other sites
Herbie 1,834 Posted January 30 Share Posted January 30 Take a look here at Lexus Parts Direct where you'll get the correct one at £117.76 Quote Link to post Share on other sites
Jayw13702 297 Posted January 31 Share Posted January 31 On 1/30/2021 at 1:05 PM, AKH said: Hi, My 12v Battery is playing up and I am baffled as to which battery to go for Eurocarparts suggested a Lion AGM battery and their website does not seem to have a standard battery choice for my vehicle Does the car need a AGM? What have you guys replaced your ones with Lexus themselves quotes £148! Regards, AKH strange, my dealer charged me £137 for mine last month Quote Link to post Share on other sites
200h 587 Posted January 31 Share Posted January 31 it goes to show the dealers will try and get as much as they can for anything they sell Quote Link to post Share on other sites
ganzoom 220 Posted February 3 Share Posted February 3 How long are people seeing out of the 12V, ours is 6 years old now and not been replaced. No signs of any issues so far. Quote Link to post Share on other sites
Bob99 30 Posted February 3 Share Posted February 3 Over 7 years at the moment out of mine. Since the lockdowns started I have charged it a couple of times, at other times I sit in the car when my wife is in the supermarket with the engine on to give it a boost. Quote Link to post Share on other sites
matt8 96 Posted February 3 Share Posted February 3 5 hours ago, ganzoom said: How long are people seeing out of the 12V, ours is 6 years old now and not been replaced. No signs of any issues so far. Sept 2013 Car. Replaced for the first time in June 2020. Nearly 7 years old. It was truly knackered at this point though. Quote Link to post Share on other sites
westo3 28 Posted February 3 Share Posted February 3 Replaced after four years mainly due to leaving car at the airport for 4 weeks last January. Never really recovered, staggered on over the following year finally giving up the ghost on the cross channel ferry which was a little annoying! Quote Link to post Share on other sites
paulrnx 368 Posted February 3 Share Posted February 3 If fitting a non OE Battery make sure the terminals are oriented the same. Quote Link to post Share on other sites
malcolmw 283 Posted February 3 Share Posted February 3 32 minutes ago, paulrnx said: If fitting a non OE battery make sure the terminals are oriented the same. +1 on this! There are many batteries with similar dimensions and terminal types which will physically fit but have the opposite polarity. Be very careful. 1 Quote Link to post Share on other sites
PRT68 99 Posted February 3 Share Posted February 3 Don't go to Lexus Milton Keynes. Tried to charge me £395.00 for a similar Battery for my RC300h. Won't darken their door again. Quote Link to post Share on other sites
Hadrian 72 Posted February 4 Share Posted February 4 On 1/30/2021 at 4:24 PM, Herbie said: Take a look here at Lexus Parts Direct where you'll get the correct one at £117.76 I tried them, they are out of stock, and don't know when they will be getting more I've ordered one from here.. £149.99 including delivery https://www.ebay.co.uk/itm/383442807287?fbclid=IwAR0LcBym4mK0YBNKYa1pA3rPxUJTl6zr1q2AH6n1TZen0dOb_qtuohkpQaY#vi-ilComp They also say the following PLEASE LEAVE THE CAR RUNNING FOR AT LEAST 1 HOUR AFTER INSTALLING THE NEW Battery SO THAT IT CAN REACH TO ITS FULL POTENTIAL. Battery NORMALLY FAILS DUE TO REDUCED VEHICLE USAGE OR FREQUENT SHORT JOURNEYS. Battery IS AN ELECTROMECHANICAL DEVICE WHICH NATURALLY LOSES CHARGE OVER TIME AND LOSES CHARGE EVEN FASTER IN HIGH SPRING AND SUMMER. EVEN WHEN VEHICLE IS OFF & LOCKED, ALARMS AND ELECTRICAL SYSTEM WILL DRAIN THE Battery BECAUSE Battery IS STILL CONNECTED TO FUNCTION ALARM & OTHER VEHICLE INTERNAL COMPONENTS. ALL HYBRID CARS REQUIRED MORE THAN 40MINS DRIVE OR AT LEAST 1HOUR IN “READY” MODE. IF NOT USING CAR REGULARLY LEAVE THE CAR RUNNING FOR AT LEAST 1HOUR TWICE A WEEK. IF Battery LEVEL IS DROPPED BELOW 80% AND NOT QUICKLY RECOVERED BY RECHARGING THEN IT WILL CAUSE PERMANENT DAMAGE TO THE Battery. DAMAGE OCCURS BELOW 10.5VOLTS. BATTERIES ARE NOT DESIGNED TO GO BELOW 12VOLTS BY THEMSELVES AND CAN ONLY GO DOWN BECAUSE OF OVER DISCHARGE ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ## ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Leaving the car running for an hour twice a week seems OTT. Connecting to a charger for half a day every week should suffice (?) Chargers won't (or shouldn't) let you over charge. Quote Link to post Share on other sites
Brechin Slate 170 Posted February 4 Share Posted February 4 31 minutes ago, Hadrian said: Leaving the car running for an hour twice a week seems OTT. Connecting to a charger for half a day every week should suffice (?) Chargers won't (or shouldn't) let you over charge. Once a week for an hour is the current recommended procedure. Leave it in P with no radio, lights, A/C etc and the engine will cut in and out as required. A smart charger is another option, quite a few to choose from, I bought a NOCO Genius 5 from Halfords using the club discount but the Cetek MXS 5 seems popular with Lexus owners. Quote Link to post Share on other sites
Hadrian 72 Posted February 5 Share Posted February 5 On 2/4/2021 at 9:04 AM, Hadrian said: I tried them, they are out of stock, and don't know when they will be getting more I've ordered one from here.. £149.99 including delivery https://www.ebay.co.uk/itm/383442807287?fbclid=IwAR0LcBym4mK0YBNKYa1pA3rPxUJTl6zr1q2AH6n1TZen0dOb_qtuohkpQaY#vi-ilComp The battery was delivered today, maybe not the cheapest option but at least I now have it. It's labelled as Toyota..Made in Korea........... Close enough for me and the correct dimensions Quote Link to post Share on other sites
Colin Crow 5 Posted February 5 Share Posted February 5 My dealer replaced my faulty 12V battery today for £125. I've only had the car for a year, but I would guess the previous Battery came with the car in late 2016. Quote Link to post Share on other sites
