Chrisintown 0 Posted February 10 Share Posted February 10 My light control relay is playing up, humming noise from relay and lights flicking. Happened before and replaced relay with used part, now has started again few years down the line. Seen some on welknown auction site but all in USA. Is there anywhere in UK can buy? Quote Link to post Share on other sites
Herbie 1,821 Posted February 10 Share Posted February 10 First thing you need to do is take it out and see if there are any markings or model numbers on it and maybe even a circuit diagram on it so that we know what we're dealing with. Once you can identify it have a look at some of the places here for a spare. If there are no identifiers on it then you can either use a 12V supply and multimeter to map out the operation on the bench, or, last resort but probably easiest is to get one from a Lexus dealer. Quote Link to post Share on other sites
Chrisintown 0 Posted February 10 Author Share Posted February 10 3 hours ago, Herbie said: First thing you need to do is take it out and see if there are any markings or model numbers on it and maybe even a circuit diagram on it so that we know what we're dealing with. Once you can identify it have a look at some of the places here for a spare. If there are no identifiers on it then you can either use a 12V supply and multimeter to map out the operation on the bench, or, last resort but probably easiest is to get one from a Lexus dealer. toyota 85916-30060 056800-2280 light control relay 12v Denso Quote Link to post Share on other sites
