alanann 3 Posted February 10 Share Posted February 10 My 2010 Rx450h seL has the air suspension and i want to check the ride height cos offside front is slightly lower I have had a look but can't see the height sensors, can anyone help with the locations? thanks. Quote Link to post Share on other sites
Herbie 1,831 Posted February 11 Share Posted February 11 Just sent you a PM that should help you with that Alan. 1 Quote Link to post Share on other sites
alanann 3 Posted February 11 Author Share Posted February 11 Thanks to Herbie I got the info I need. 2 Quote Link to post Share on other sites
alanann 3 Posted 19 hours ago Author Share Posted 19 hours ago On 2/11/2021 at 12:15 AM, Herbie said: Just sent you a PM that should help you with that Alan. Hi Herbs, I found the sensors ok, I need to check the heights to see which corners are high or low, Would it be possible for you to check the heights on your car either ground to wheel arch or wheel centre to arch. Thank you Alan. Quote Link to post Share on other sites
