Subtronics 19 Posted February 12 Share Posted February 12 Hi, has anyone fitted an FSport speedo cluster to a non FSport? I really like the moving part in the f sport and found one on ebay, but its very expensive and wouldn't want it to not work! Quote Link to post Share on other sites
NemesisUK 1,628 Posted February 12 Share Posted February 12 It'll need a lot of coding to make it work, plus additional wiring and changes to the steering wheel to include the button to move the display? 1 Quote Link to post Share on other sites
paulrnx 368 Posted February 12 Share Posted February 12 A big job I would think. Selling and buying an F-Sport could be cheaper. Quote Link to post Share on other sites
Subtronics 19 Posted February 12 Author Share Posted February 12 Yeah, I figured so. I can imagine all the coding is handled by the ECU. So maybe possible if the ECU is swapped out. Probably cheaper buying an FSport lol Quote Link to post Share on other sites
ColinBarber 2,113 Posted February 12 Share Posted February 12 45 minutes ago, Subtronics said: Yeah, I figured so. I can imagine all the coding is handled by the ECU. So maybe possible if the ECU is swapped out. Probably cheaper buying an FSport lol The instrument ECU is built into the instrument cluster itself. It is possibly all self contained. Whether the plugs are the same or other changes on the body ECU are needed I don't know. 1 Quote Link to post Share on other sites
Subtronics 19 Posted February 12 Author Share Posted February 12 Thats really interesting! I will have a google see if I can find out if the plugs are the same on the back. Might be possible after all. Quote Link to post Share on other sites
Subtronics 19 Posted February 12 Author Share Posted February 12 So, from a very quick look, the connectors look the same, just in different locations. Got a few bits I want to sort first, but I may well give this a try. Quote Link to post Share on other sites
Pink 36 Posted February 13 Share Posted February 13 It’s a very funky party trick, and I’m probably sounding very old-fashioned, but I personally prefer the symmetry of two dials. Then again I always have brown sauce on the chips, whereas the wife says it just has to be red. Go figure! Quote Link to post Share on other sites
200h 587 Posted February 13 Share Posted February 13 ask Ianhu his cluster didnt work properly on his F sport and he managed to get his cluster to work properly on his car but it took him alot of time and effort i would say he's best one to ask on here i'll try and find a link for you Quote Link to post Share on other sites
200h 587 Posted February 13 Share Posted February 13 heres the link Quote Link to post Share on other sites
ColinBarber 2,113 Posted February 13 Share Posted February 13 The problems there were mainly because it had been swapped/messed with, seemingly to change the mileage, and possibly it wasn't the correct one for the age/options of the vehicle. But yes it may not be as simple as just swapping it over and everything works. Quote Link to post Share on other sites
200h 587 Posted February 13 Share Posted February 13 yes i know colin but Ian probably has the best knowledge on here regarding the F Sport dash and how it works and wether it can actually be retro fitted to another model Quote Link to post Share on other sites
ianhu 24 Posted February 15 Share Posted February 15 Hi What I did wasn't a real lot to be honest. The milage wasn't clocking up as it should. I deciphered the code locations of mileage, of which there are two, one for the displayed mileage and another with the incremented figure ready to be moved to the displayed location and rinse repeat. Anyway short of sorting that correctly and then flashing it back to the IC, and fit/test was about it. Interestingly, my two code locations had the same figure in then, hence it not clocking up. The pusle was certainly there to make the increment but I think because locations A and B contained the same hex figures for the displayed and new mileage I guess the unit froze on what to do. The bigger question is why did it get like that, why did I find some other person with the same issue in the same mileage approx area, and why do I now have a guy who's contacted me with the self and same issue with his f sport. No coincidence me thinks. Anyway.. certainly the logic to move the dial etc will be contained on the code in perhaps another IC involved in moving the display as well as moving the motor etc. My best guess is that power rails etc the data rails are most likely also the same fed to the clock and the clock is responsible for dealing with them. My best guess (and it is just that) is that they are likely interchangeable, but rightly as others have said you still need the buttons on the wheel to actuate the moving display. The simplest test is both cars together and do a swap to see. Short of that I wouldn't shell out anything personally. 1 Quote Link to post Share on other sites
Mincey 335 Posted February 16 Share Posted February 16 I wouldn't bother changing the display to be honest. The F Sport dial moving thing soon gets boring and becomes a bit old hat. I'm lying. It doesn't 😉 1 Quote Link to post Share on other sites
ColinBarber 2,113 Posted February 16 Share Posted February 16 On 2/15/2021 at 8:49 AM, ianhu said: , but rightly as others have said you still need the buttons on the wheel to actuate the moving display. I think all the non F-Sport vehicles also have the button, just used for a different purpose: Quote Link to post Share on other sites
shine668555 6 Posted February 19 Share Posted February 19 I'm currently working on this, still in early stage but yes, f sport clusters can be fitted to non f sports. Physically the same, plugs the same as long as f sport clusters is from the same model year and edits. So say 13-14 14-16 17+ steering wheel buttons don't change on any model of 300h. Only if you have an advanced safety pack you get extra two buttons for acc and ldw regardless of trim. Anyways, once I figure out everything I will make a post. (Gonna be a while) I'll be able to program up the correct mileage, and options depending on your trim level. 1 1 Quote Link to post Share on other sites
Subtronics 19 Posted February 23 Author Share Posted February 23 On 2/19/2021 at 11:39 PM, shine668555 said: I'm currently working on this, still in early stage but yes, f sport clusters can be fitted to non f sports. Physically the same, plugs the same as long as f sport clusters is from the same model year and edits. So say 13-14 14-16 17+ steering wheel buttons don't change on any model of 300h. Only if you have an advanced safety pack you get extra two buttons for acc and ldw regardless of trim. Anyways, once I figure out everything I will make a post. (Gonna be a while) I'll be able to program up the correct mileage, and options depending on your trim level. I'll be interested in this when you figure it out mate. If you need a car to test on let me know 🙂 Quote Link to post Share on other sites
shine668555 6 Posted February 23 Share Posted February 23 1 hour ago, Subtronics said: I'll be interested in this when you figure it out mate. If you need a car to test on let me know 🙂 I'll do a post up but yeah as said will be a while as I'm moving real soon and baby takes most of my time ATM but I'm slowly getting there. Thanks for the offer buddy, I have a non f sport myself here and an f sport cluster to play with. 1 Quote Link to post Share on other sites
Subtronics 19 Posted Thursday at 10:17 PM Author Share Posted Thursday at 10:17 PM Look forward to seeing it in action! There are a couple of FSport bits I want on mine. Front end and interior. But just got to wait for them to come up cheap somewhere. Quote Link to post Share on other sites
200h 587 Posted Thursday at 10:32 PM Share Posted Thursday at 10:32 PM the only interior items i would change are the A B C pillar caps and the head lining both in grey to black like the F Sport Quote Link to post Share on other sites
