Navnan2 20 Posted February 13 Share Posted February 13 Got my UX at the end of last year and haven't had the chance to use it much. Tonight I popped out which must be my first night drive. I was sure I had seen in one of the Youtube road tests that the air vents controls in the dash were lit with a blue hue. Mine are not lit. Is it a feature on certain spec models or am I just dreaming? I have a premium plus base model. Thanks. Quote Link to post Share on other sites
ALAW 45 Posted February 13 Share Posted February 13 Evening Barry if its any consolation my f sport Prem plus doesn't. I am pretty sure this feature was only on the Takumi. 1 Quote Link to post Share on other sites
ColinBarber 2,115 Posted February 14 Share Posted February 14 Yes, only on the Takumi Quote On the UX Takumi, the vents are illuminated by a distinctive LED light source. This is wirelessly powered by the electromagnetic resonance of two adjacent coils vibrating at the same frequency. Using the same design principle as the Lexus LC’s rear combination lamps, the vent control LEDs use mirror optics to create the effect of floating lighting depth, even though the light element is just 3mm thick. Quote Link to post Share on other sites
Navnan2 20 Posted February 14 Author Share Posted February 14 2 hours ago, ColinBarber said: Yes, only on the Takumi Many thanks Colin, now got to decide if I keep the car...............just joking! Cheers, Barry 1 Quote Link to post Share on other sites
paulrnx 369 Posted February 15 Share Posted February 15 On 2/14/2021 at 2:17 PM, Navnan2 said: Many thanks Colin, now got to decide if I keep the car...............just joking! Cheers, Barry It could have been worse. You could have booked the car in to have this issue looked at! 😀 Quote Link to post Share on other sites
Navnan2 20 Posted February 18 Author Share Posted February 18 On 2/15/2021 at 6:13 PM, paulrnx said: It could have been worse. You could have booked the car in to have this issue looked at! 😀 😄 Quote Link to post Share on other sites
Navnan2 20 Posted February 18 Author Share Posted February 18 Colin, could I bother you again? I recently found the "concierge" climate control option. Sounded good to me, got my temperature set and car sorts everything out for me. I have found though when I start my vehicle on a new trip and check the climate options screen it no longer highlighted so I have to set it again. Do you use this option? Am I suppose to select concierge everytime I use the vehicle if I like this facility? Seems a bit odd to me. Cheers, Barry Quote Link to post Share on other sites
ColinBarber 2,115 Posted February 18 Share Posted February 18 1 hour ago, Navnan2 said: Sounded good to me, got my temperature set and car sorts everything out for me. I have found though when I start my vehicle on a new trip and check the climate options screen it no longer highlighted so I have to set it again. I wouldn't expect the need to turn it on every time. The A/C system should be in Auto mode, then enable concierge. Does the system still work even though the icon isn't highlighted - i.e. do the seat heaters come on? I wonder if part of the system is disabled, e.g. because a passenger not sitting in the seat, so the icon goes out but the remaining systems are still working. Quote Link to post Share on other sites
paulrnx 369 Posted February 19 Share Posted February 19 Surely concierge mode is a mode that allows no or very little adjustment of the various controls? It would be a mode for when you pull up at a hotel that you can set to make sure no-one from the hotel messes around with the controls when they valet park it for you? At least this is what concierge mode would suggest to me. Quote Link to post Share on other sites
ColinBarber 2,115 Posted February 19 Share Posted February 19 1 hour ago, paulrnx said: Surely concierge mode is a mode that allows no or very little adjustment of the various controls? That is what it does. You set the desired temperature and the system will control seat heaters/coolers and steering wheel heater based on the actual cabin temperature as well as just the standard climate control system which a normal system will do. Nothing to do with locking control settings for valet parking. 1 Quote Link to post Share on other sites
