Software tells me cylinders 2 and 6 not in sync leading me to think it might be the sensor on the crankshaft is faulty.Can anyone tell me if this is a big job for a garage to do Thanks
Is this the diagnosis from an error code? Are you noticing anything untoward when the engine is running? Is there vibration and can you detect a misfire?
Slight misfire very fine but software tells me cylinder 2&6 slightly out of sync I just thought it would be the sensor on the crankshaft not communicating properly with the ecu BUT this is not my area of expertise.
Jim
Straight 6 ,think I will replace camshaft and crankshaft sensors and see if there is a difference won't do any harm Both sensors are easy to access and reasonably easy I believe to change.I am upgrading my software to main dealer software on a laptop it may help identify the problem.The car is really sluggish and I feel a slight vibration over 50
Jim
Jim
What are your codes, P0302 and P0306?
