 Basic Help & Repair
'02 Lexus IS200 (Auto) MISFIRE with no codes!
Jump to LatestUnfollow
1 - 1 of 1 Posts
 Buttons
Registered
Joined 2 h ago
 Discussion Starter • #1 • 2 h ago
Hey people, it seems I am in need of some assistance... I recently purchased a '02 IS200 (700miles ago @ 91k) ran absolutely perfectly for about 650miles or so before I started to experience low idle rpm's and what seemed to be a random misfire. Happens mostly at idle and little acceleration but seems to disappear when I put my foot down. I have checked/done the following:
Checked ignition coils and spark (changed spark plugs back to old ones, no change and have visual spark)
Checked for clogged cats (only tested front cat as when I did, the misfire continued and sounded more prominant, so im thinking misfiring in either cyl. 1, 2 or 3)
Checked Fuel Injectors (checked resistance, all good, BUT, there was alot of oil or fuel present in the connectors and injectors in Cyl. 2, 3 and 4 after cleaning and driving the car, checked again and a small amount of oil or fuel visible again)
Cleaned the TB inlet and butterfly which left the car Idling very high now (1500rpm) but I did reset the ECM so maybe just learning again
ALSO I cleaned the OCV filter and tested the OCV which was in spec. BUT i didnt test to see if it operates under voltage.
and STILL, no change.
Sorry for the essay but I hope someone mgmight have some ideas for me!!
