Hi
I'm nearly up to date with proactive maintenance although I admit I need front upper carrier arms.
Last job was rear discs and pads that are now bedded in.
Next job will be annual oil & filter change: Lexus oil is now priced more competitively than the Euro brigade so i'll be on the Lexus Parts Direct site.
Problem:
- Cold morning I noticed for the first time a bass level drone resonating from the front end.
- Now seems ever present although sometimes more noticeable than at others.
- Not tyre noise as I can hear that distinctly and vary over different surfaces. No out of balance symptoms.
- Speed range 40 - 60 mph.
- It's not engine related as engine speed does not effect it.
- Breaking does not seem to change it either.
- I get a general slight/low level of vibration - but not through the steering.
- Tyres are up to pressure with 4MM+ tread - a bit more fronts wear outer edge but I've had worse.
- Once I had the sensation it was front of vehicle passenger side.
It's nothing obvious and unlike me, although I will fret on it, I'm inclined to leave it until the issue clearly identifies itself if it doesn't drive me mad first.
Any ideas..?
Had something similar a long way back, was only cured with new tyres, as it was tyres which had worn oddly and were not going to play ball even when I had a full alignment done as they were never going to sit right on the road.
The lesson I learnt was even with new tyres, do an alignment check every 5,000 miles (max) given state of UK roads.
Try swapping fronts to rear and see if it helps.  If not then is there something just flapping around.  Once had a cavalier where part of bumper had come a bit loose and hummed at motorway speeds, cured with some superglue (I recall)
thinking about an Alfa Romeo we had on our garage forecourt for sale long time back ........   the front wheels / tyres had flat spots / areas ....  not obvious to the eye nor to balancing etc ......  could be the tyres .........  what make / age / miles are they I wonder
I had a brake dust shield that was rusting through and was loose and that made some strange noises.
Hi
I’m wondering about the wheel bearing.
My fridge freezer motor is in the process of packing up...please bear with me...😉
Now I can hear the high end damage of the bearing motor-but it is also creating a low bass droan too.
Tyres are Continental 16” diameter...balanced a while ago...I’d expect feedback through the steering wheel yet all is good. Same with flat spots...I’ve had those funnily enough on my Alfa 155.
I can’t get it up on a jack until the weekend.
Check the wheel bearings for play and noise.
Check for any loose alternator, power steering nuts and bolts.
Check for worn engine thrust bearing, simply pull forward and push back the crankshaft pulley.
Check the engine mounts for wear.
Chris.
10 hours ago, Tinonline said:
on my Alfa 155.
I don't like to say this BUT when we looked, many years ago now,  at Alfa stuff the local Agent in Canterbury had it's workshop full of engines on benches being repaired .....  it seemed to be that the life of a cambelt was usually much much less than the service book schedule ..............  we discovered it was safer to renew them every 15k miles max
just my thoughts from a while back :unsure:
Hi Malc
Yes they have their magic!
Mine is an old 1995 Sport with a chain driven 1.8 - had the head-gasket done a few years back.
It's an LHD and sits in a garage in Spain for most of the year. Now a classic, it feels a bit long in the tooth but it goes very well, has aircon, and we've done a lot of mileage in it. Wife is Spanish so we have roots there. Handy when fixing the car. 🙂  Parts are expensive - labour cheap. Before Brexit I shipped parts from the UK. I'm not going to get the needed 3/4 exhaust system into hand luggage...🧐
Simon
  • 1 month later...
At last now the weather is with us I jacked the car up.
Neither wheel had any play, however the drivers side had a regular click when I spun the wheel. I was sure the vibration noise was passenger side but I suppose it might just seem that way...
Nothing is catching and brakes are recent and in good shape.
Surely has to be the bearing?
Completed an oil change too so that’s for another year.
Come to think of it: drivers side with click click noise rotated freely.
Passenger side where I thought issue is: sounds like brakes rubbing and does not spin so freely but maybe not brakes...
Could it be a wheel balancing weight just clipping the calipers, though usually only happens after a new tyre fitted and it is an apprentice who does not know clearance on LS is pretty tight.
I’m going to have a thorough look once again...my diagnosis is usually very fair but this has me a bit at odds.
Oh I know I’ve taken so long to get to this.
I was sure the LH bearing was going…all noise was on that side. I checked the balance weights, visual inspection of joints all looked good.
Imagine my shock on a journey when under braking terrible scraping noise erupted from left hand side. Checked the mileage since last brake work…can’t be worn already…despite my driving style.🤭🤫
Then the terrible grating from driver’s side on slow steering on reverse…how I slept that night I’ll never know.
Well, the terrible scraping was a corner, loose and hanging from the engine undercover…snapped and held by a single bolt. Sorted that.
Back to the driver’s side front. Definite clicking on rotating the wheel. Creaking is from that side. Ahh…with hands 10 to 5 I can feel movement.
How difficult to fix at a garage? Ok chucking it at Lexus but nobody else wants to know. That’s it. Fed up. A wheel bearing looking like a minimum of £300 to fix. Forget it.
For now: skf kit with bearing, oil seal, nut, snap ring comes in at 60 quidish. Either someone will deign to fit it for me or I’ll take the thing out for disassembly and reassembly.
I could do it…but I don’t want time and complication of sourcing the tools. Or more cost for a one off job. The Lexus service guide shows hand tools deployed…can’t see a 5 ton press in sight…tempting…
I'm pretty sure you will need a press to do it yourself, for removing/installing the Axle Hub and for removing/installing the bearing. That is once you've removed the steering knuckle itself to work on.
This is great: the later marque 400 instructions.
Yes so a press is needed.
Would one of the 5 ton pullers work, available on eBay?
I’ve no idea if a 5 ton puller would work, I’d either buy a press or take the axle hub assy to a garage or engineering company for them to press all the stuff out and refit.
Yes this the option I’m going for. Get it a place that will do it.
I did part one of the job this morning.
All went very well. To my surprise…and the upper arm ball joint seems to be ok which I didn’t expect.
To get the nut cap or cover off I just firmly tapped around and levered with a screw driver and mallet.
To stop the upper arm ball joint bolt from turning I held it with a thin pair of grips to get the nut off the last bit.
