IS220d won't crank/start - HELP!
2006 IS220d. Battery replaced a few months ago and have checked that it has plenty of power so not that.
Green light comes on, all the checks are done. Clutch down, press again and it just turns off.
Tried the accelerator, that didn't help. Have had the Battery disconnected for 30 seconds, not made a difference.
I'm wondering if it is immobiliser or starter? Obviously we are down to one car at the moment so are totally stuck!
Hi Adam,
Can I just check what is happening; you press the button once and the car powers up (so called Accessories mode) but when you put your foot on the clutch and press it a second time, it turns off rather than turning over the engine?
Have I got that right?
